My motherboard manual says it supports up to 512MB DIMMs, but a max of 4GB memory. How am i supposed to archieve 4GB with 4 slots of 512MB RAM?
DFI LanParty NF4 SLI-DR
Lenovo/IBM ThinkPad T61 Widescreen 15.4" 1680x1050
Intel Core2Duo T8300 2.4GHz | 3GB DDR2 from Hynix | SATA II Patched bios (Middleton) | Samsung EVO 850
Arch Linux | Linux 4.3.X x86_64
https://linustechtips.com/topic/199074-4gb-max-memory/
Erm, you buy a new motherboard, and CPU, and RAM, and a whole dam system. Seriously please refresh from a 9 year old system, unless ofc if your fine with just playing Minesweeper.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698685
He could have more than 1 system, dont have to be a prick about it. Not all people can go out and buy a new system. Also OP is only 15 so chances of having a job are slim.
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698691
Dude, you need Titans in 4-way SLI to even get Minesweeper playable in 720p on low.
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698692
Get better system. At least on i3 if you're bad in financials.
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698694
Theoretically it's chipset can support up to 4GB
But if you're still using a system like that, I suggest that you get a new one... Buying new RAM will cost you a lot, so it'll be more cost effective to get a new system altogether.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698698
According to reviews of this board from 2005, the board supports 1GB DIMMs.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698709
I need a PC for internet only and mild gaming, as i got the motherboard for 25$ and i can get 4GB of G.Skill ram for another 20$.
The last time I've had 512mb in my system, Pentium 4 was still relevant...
Okay.
get 4 512mb ddr ram sticks. I suggest getting a new system because socket 939 is dead, even you add 4gb of ram, your system won't run fast.
Here is all cheapo, so yeah, why not build a 2005 gaming pc.
I've never heard of a capacity limit per DIMM on a motherboard before
Awsome.
Downloading the other 2GB of RAM, duh.
Okay.
And all parts are damn cheap here also !
Ofskroz.
Nope.
No it wont, since i must pay 300Euros for a i3 here.
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698719
Okay.
Awsome.
Okay.
Ofskroz.
Nope.
you will need 4 512mb ddr 400 ram sticks to get 4 gb of ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16813136151
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698727
except 512x4=2048 which is only 2GB of ram
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698731
Wouldn't getting that ancient of memory be more expensive than even inflated DDR3 prices? I remember DDR2 being laughably expensive, cant imagine DDR being cost effective, either.
cheap, around 15 bucks
http://www.amazon.com/Kingston-ValueRAM-Desktop-KVR333-1GR/dp/B0009XD672
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698745
The point is, im going to build a expensive PC with a ssd, some fancy gpu card, corsair's cooling and all the blows and whistles , and when its time to upgrade (mb dies) i just replace the motherboard. Everything else is there, PSU, cooling, case etc.
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698766
I wasn't trying to be a prick, man so many people misunderstanding me this evening :'(
Well what is your parts list atm? We might be able to guide you to a better outcome. But seriously, if your motherboard doesn't support even DDR2 than you may as well get a new one.
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698832
Bruh, more like 3 Xeons and 7 R9 295X2s. Even with that you'd be pushing up into the 9001oC range.
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698842
Okay.
Awsome.
Okay.
Ofskroz.
Nope.
Then enjoy ancient shit pc
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698845
I just attempted to launch Minesweeper on my laptop and it exploded.
Posting from phone.
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698856
I'm going guess p4 and 1GB Dims should be fine.
https://linustechtips.com/topic/199074-4gb-max-memory/#findComment-2698858
