Well, if you want a reference cooled GTX 770....you cant get a cooler and just put it on the ASUS GPU, your gonna need to return the ASUS one and buy this: http://www.amazon.com/gp/product/B00DZ35XWY/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER anyway good luck.
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
https://linustechtips.com/topic/198960-gtx-770-cooler-question/#findComment-2697073
I just bought an asus gtx 770 dcuii lol! Is it possible to switch to a stock cooler??? Is it worth it just for the looks of my PC??? Also will it impact OC performance???
It is not worth it. The reference design blower-type coolers tend to be exceptionally loud, and are not as efficient at moving heat away from the graphics card. Which with will hinder the potential performance of the GPU, considering it also needs low temps in order to automatically ramp up the clock speeds on its own. Also on another note, yes you can replace coolers on certain graphics cards however, in all likelihood you cannot replace the DCUII cooler with a stock cooler from Nvidia. I may go on a limb and say it is not possible  without some serious modifications.
https://linustechtips.com/topic/198960-gtx-770-cooler-question/#findComment-2698096
