Ugh... such high temps
There is an exhaust fan above it. The only fan slot left in this case is a 200mm on the side, but I can't install a fan there due to clearance issues with the Hyper 212.
Is there something I can do about this without spending too much? I have a reference (Asus branded) Radeon HD 6870. The fan is noisy at load, and temps are horrible. I have taken off the shroud and cooler, completely cleaned it to the point where I could eat off of it, and re-applied it with the thermal paste that came with my Hyper 212 EVO. I still get around 60 degrees idle and it hits about 90-95 degrees under load (doesn't throttle though), in a room with around 27 degrees ambient temperature. I don't want to spend too much on this card, and I feel that it's just an issue with my case which is an NZXT Phantom, since there's barely any airflow getting to the GPU area. Most of the airflow is in two areas, horizontally across the hard drive cages from the left side of the case to the right side, and from the top of the case, through the CPU cooler, and out the back.
Those are normal temps for a reference 6870 so all you can really do is put a new cooler on it, but that would be around $100, in which case you may as well just save another $100 and get a 270x.
