UPS: Help with capacity decision
By
BishamonX
in Power Supplies
in Power Supplies
Solved by Andi,
your system with monitor needs maybe 300-350W under load.
your APC Back-UPS 650VA could handle your pc fine. Don't forget that in idle your watt usage is very little. maby 50W-120W with monitor.
you could take your UPS, plug your pc in it and look if it will run, i'm 100% it will be no problem.
HunterSVK ·
Posted in Troubleshooting0 -
Ozzi ·
Posted in Networking1 -
1
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning5 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
2
1
play_circle_filled
Latest From ShortCircuit:
