R7 260X will probably be enough for that or a GTX 750 Ti.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
R7 265 is what i have and it runs amazing on highest settings
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
Hey guys i am looking for graphics card to play game rust , i want it to be able to play it on normal settings , but not to dissipoint when rendering lots of stuff . so the lowest price for rust settings listed above .
Rust will run fine on most newer integrated graphics
"Rawr XD"
I can play rust on my almost five year old laptop with a super shitty GPU. A R7 240 will likely suffice, even though something like a R7 260X would perform better, and a 7770 would probably also be a good option.
Is it a monkey? Is it an ape? I don't care, I LOVE'EM!
Guys this site http://www.links.hr/?option=katList&id_kategorija=0518&pageNO=1&sort_cat=naziv&sort_ord= is the only place where ican buy , because its in my town  and im in hurry , can you see what on that list is ok for what i want , also there are two pages ..
Whoa someone's angry. He just gave you a suggestion. You never listed a price range so you have no right to get mad at him.
CASE - CM Storm Stryker, PSU - EVGA 1000 P2 80+ Plat, CPU - i7 4790K w/ NZXT Kraken X61, GPU - MSI GTX 1080 TI Seahawk X, MB - ASUS Z97 Maximus Hero VII, RAM - G.SKILL Ripjaw X Series (2 x 8GB) DDR3 1600, SSD - SAMSUNG 1 TB, DISPLAY - ACER XB270HU + SAMSUNG S24C570HL
duude , not cheap im not playing fukin bf4 , im playing rust
You really have to behave to get decent answers, but a R9 260x will definately do the job.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
Word "cheap" is relative. So for others to give a better recommendation, it would be best if you can actually give a max price range.
