Urgent - Need help with External HDD issue
Solved by Optimus Prime,
enclosure are just an interface for converting SATA to USB
your Windows will detect the drive and install the drivers
if it already NTFS format
it will show as another drive in computer
It can't auto format without asking you for permission. You should be fine
Thanks guys
I'll cross my fingers and plug it in when my computer finishes downloading dlc
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting2 -
2
1
6
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
Shane Martin ·
Posted in Displays2
