Would I be able to get 4.3Ghz @ 1.28v on a mITX board with a 4-Pin CPU connector?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128720
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/196115-4-pin-cpu-overclocking-ability/
Probably yes. Its a Z97 after all...
I'd be using a 4770K
| F@H STATS |
I'm sure the 4pin is going to be able to supply enough power, what I'd be worried about is the absence of any form of a heatsync on the power phases. Them suckers are going to get HOT even with stock voltages running through them.
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188158
| F@H STATS |
EVGA has for the last few generations been plagued by issues on their motherboards, I recommend you extensively look into that board before buying it.
I don't know if you'd like either of these but they are both cheaper and I personally trust MSi and Gigabyte WAY more when it comes to motherboards than EVGA.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128719
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130781
The MSI was my original choice however I was also wanting to install OS X on the PC. MSI locks their BIOS, I CANNOT FOR THE LIFE OF ME get anyone to help me unlock the BIOS on my current board or in this case my future one.
| F@H STATS |
I'd help but I have literally no idea how to unlock a BIOS haha.
my 970a ds3 have a single 4 pin and you can put and fx8350 in that so you'll have tons of headroom with an intel cpu
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
