What is a healthy temperture for a cpu and gpu to run at, i have a 4th generation intel i7 and a nvidia 755m if it makes a difference
My Cheap But Good Rig: I7-3770s, Intel Motherboard (actually made by intel), 16gb DDR3, Nvidia Gtx 1070, 250gb Samsung 850 EVO SSD, 750gb HDD, Evga 500 BR power supply
https://linustechtips.com/topic/193926-laptop-cooling/
Laptops will run hot, especially while gaming. If you are concerned about temps, a cooling pad might be of use. The laptop should be able to provide sufficient cooling, even if it feels warm. Temps will obviously not be ideal due to cramming components in small spaces. What are your temps?
I should be studying.
https://linustechtips.com/topic/193926-laptop-cooling/#findComment-2628752
yeah my laptop gpu runs at 68 degrees celsius just wanted o know if that is bad while gaming i dont think it is that bad but i wanna make sure
https://linustechtips.com/topic/193926-laptop-cooling/#findComment-2628762
laptops run hotter. Honestly it depends on the design of your laptop, and what it is intended to run at by design. Thinner laptops may run in the 80s, where my laptop ones like it run games at below 60. Look at posted temps in reviews for your particular model.
As long as it's within the range it is supposed to be at for that laptop, don't worry.
Notebookcheck is a good place to start.
I'm guessing you have a y500 or similar? Y510p?
From my memory the y500 style ones run really hot.
https://linustechtips.com/topic/193926-laptop-cooling/#findComment-2628765
85-95C is the danger zone :P
https://linustechtips.com/topic/193926-laptop-cooling/#findComment-2628826
If you really want to, get a cooling pad, this seems like a good one:
http://www.amazon.com/Cooler-Master-NotePal-Cooling-R9-NBC-NPX3-GP/dp/B0079T2KHG
Main PC:
ASUS F1A55-M LX, AMD A6-3500, (2x2)gb Kingston HyperX Blu DDR3 1600mhz, Seagate Barracuda 500gb 7200rpm,
 Corsair CX430M, Cooler Master Elite 343, Windows 8.1 Pro 64-bit
Netbook:
Lenovo Ideapad S10-2, Intel Atom N280, (1x1)gb DDR2 667mhz, WD Scorpio Blue 250gb 5400rpm, Zorin OS 9 Lite
https://linustechtips.com/topic/193926-laptop-cooling/#findComment-2628827
and 75-64  is the HIGHWAY TO THE DANGER ZONE! Duh duh, duh duh
(and some laptops just run that hot. It's how it is.)
75-64 is not a problem for intel CPUs or nvidia GPUs. If it was an AMD CPU that would be too high, but for the OP it is completely safe.
https://linustechtips.com/topic/193926-laptop-cooling/#findComment-2628891
i have a y510p which isnt that bad with overheating the fan isnt loud and blows air hard but i am probably just gunna get a cooling pad
https://linustechtips.com/topic/193926-laptop-cooling/#findComment-2628904
you missed the reference.
Sorry :(
https://linustechtips.com/topic/193926-laptop-cooling/#findComment-2628966
