EDIT: There is a reason that I could get the CPU down to 4c, I had an air conditioner pointed at the rad, And yes I know you can't cool below ambient with watercooling parts alone...
This is now my second water cooled system, but the first I have built for myself. So here's the story...
Back in 2011 I built a FX-8150 system for Graphic design in Cinema 4D and after effects and a bit of gaming too. Both Cinema 4D and affects take a whack-tonne of CPU power to use. With all that power came a lot of heat so I switched out the stock heat skink with a akasa X4 cooler which could keep it at a reasonable temperature @ stock clocks (~60°C under load). Since then it has been sitting under my desk chugging along and collecting dust, Until very recently...
I’d been wanting to do some overclocking for a long time to speed up the render time however I could not because of thermal limits. Why? For the same reason Linus does it: http://youtu.be/QBfXruwe8w4?t=57s . So an upgrade was in order.
I have, sorry, had a large air conditioner that recently started spewing coolant everywhere, so I cannibalized it and salvaged the evaporator radiator which has a very high fin density and a nice flow rate. I then strapped it to the side of the case and called it a day. This was to be the radiator for my water cooling loop. I then mustered every penny I could find and bought an EK supremacy LTX waterblock, a Laing DDC pump and an XSPC pump top and resivoir combo. Condensation on tubes was also a problem so I bought so anti-condensation tubing :)
I'm still running a crappy GT430 GPU that runs games fine on low settings, but it needs a upgrade badly.
List of components:
AMD Bulldozer FX-8150 @ 4.6Ghz
ASUS Sabertooth 990FX
GeForce GT430 (Yep, the overpriced graphics card that Linus said was a stupid and no one should buy)
Crucial Ballistics Tactical Tracer 12GB
XFX Pro 450W Power supply
2X WD 1TB Black HDD in raid 0
All housed in the Zalman Z9+
The Finished System
post-113534-0-52714300-1407350020_thumb.
CPU Socket
post-113534-0-11023700-1407350027_thumb.
Radiator
post-113534-0-48441400-1407350035_thumb.
post-113534-0-91920600-1407350039_thumb.
I drilled into the pipe slightly... So I fixed it some random epoxy. *Remember, Do as I say not as I do*
post-113534-0-71612200-1407350044_thumb.
Temperatures @ 20c
Idle at desktop: ~4c
Prime 95 for 4 hours @ 4.6GHz: ~31c
post-113534-0-53608700-1407350049_thumb.
https://linustechtips.com/topic/193120-crazy-custom-sub-zero-ish-pc-cooling/
you are just using the rad itself? in that case i want to know how you broke the laws of physics?
i could understand if its working and used to cool freezers..
It's probably like 40c actual since the AMD thermobobbers are wrong at low temps.
either way it's cool
Error: 410
amd seems fun.. now i hear that their "thermobobbers" cant read lower than what 40 something, and if the cpus goes above 65 they overheat/burn if they dont shut down... amd sucks :S
Proud Member of the Glorious PC Master Race
This is either a troll or a really stupid idiot. You cannot cool below ambient temperature with just a radiator. You need to use phase-change to get below ambient temperature just like a fridge/freezer does. It is not possible with just a radiator.
EDIT- seems like the general agreement is the shit AMD thermal sensors. That would explain the fake idle temps.
You can't cool below ambient...
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
http://www.tomshardware.co.uk/forum/275185-29-exploring-ambient-water-cooling
Going below ambiant temps is possible with PC rads however that radiator has such a huge surface area I guess it just works anyway...
So let me ask, if you blow 20c air across water, how does it go past 20c? Temperatures equalize. Energy goes from a higher temperature to a lower temperature I believe. We were taught this in physics this year but I can't remember the specific name for it.
That guy had ice from the looks of it...
Thermodynamics, thermal equilibrium, and Newton's cooling law.
Error: 410
no, its not possible with just radiators. You need peltiers, liquid nitrogen or something like a freezer.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
I was thinking something energy. Like a cup of coffee has more/less XXXX energy than an iceberg.
