So yeah, I have this friend and he wants a low end gaming PC for mostly League of Legends, it doesn't need ultra, or anything like that, just needs to run smoothly on medium/low.
So I will give him my old 500w CX PSU, and I will also give him an old GTX 460 GPU.
So those 2 things are taken care of.
We will get a cheap 30 euro case.
A 15 euro DVD reader
But now on to the CPU.
Would a 750K be enough? He isn't going to overclock it on a budget motherboard obviously, but would the FPS be okay? Would it hit 60?
We also have a 120GB SSD in his build
Vendor is this btw: https://www.alternate.nl/Aerocool/V3X-Advance-behuizing/html/product/1090275?tk=7&lk=9285
Feel free to build, limit is 300 euro. :P No GPU or PSU needed.
https://linustechtips.com/topic/192993-extreme-budget-build/
Get a Intel Pentium K Anniversary G3258 OP.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2616055
Why? Is it better for the price?
It's slightly cheaper than the 750k, has better single core performance and can overclock very well on air - you can hit 4.5GHz with a decent aftermarket cooler.
http://www.bit-tech.net/hardware/2014/06/24/intel-pentium-g3258-review/5
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2616103
It has an upgrade path unlike the 750k
My Computer (Yet to be named)
Processor: Intel i7 5930k @ 4.4 Cooler: Corsair H100i Motherboard: Gigabyte X99-SLI RAM: 16GB EVGA 2666Mhz 4x4 Graphics Card: PNY Geforce GTX 980 ti  Storage: 1x Intel 730 240GB / 2x Kingston HyperX 3K 240GB PSU: Corsair RM650 Case: NZXT S340 Monitor: Asus VG248QE Keyboard: Razer Blackwidow Ultimate 2013 Mouse: Razer Deathadder 2013
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2616115
It's a dual core with hyperthreading btw.
I highly doubt he will upgrade from that. :P But yeah sure.
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2616142
Ok with that said then he only needs the better cpu and you already said he won't overclock.  Also LOL only uses 2 cores.  I would say for this person just get the cheapest cpu of the two and be done with it.  To be honest I really don't like people who build a pc with this sort of mentality that the OP's friend or whatever has but it is what it is.
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2616250
Video cards use PCI-Express, while most network adapter cards (that I know) use a regular PCI slot. I'm sure you can tell the difference.
But why ? Since you already have a RJ45 LAN port ? Or you mean a Wi-Fi card ?
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2616654
I Have a AMD Athlon II X3 and a GT220, and i get about 70 fps on LoL lowest settings, so your stuff should be enough :D
Build: GPU: MSI GeForce GTX 780 CPU: Intel i5 4690 MoBo: AsRock Fatal1ty H97 Killer RAM: Kingston HyperX Beast 16GB PSU: Seasonic 550W 80+ Gold Case: Corsair Obsidian 500R
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2618066
Hyperthreading? Where? O.o
"an obvious supporter of privacy"
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2618556
Derp, my bad - i thought it did since it's a Pentium. Seems i was wrong, oh well. Still great for it's price tbh.
https://linustechtips.com/topic/192993-extreme-budget-build/#findComment-2618599
