I have this problem with choosing a cpu cooler for my system. And before you comment about the Noctua NH-D series and the Cooler master EVO, i know they exist and maybe either one of them will be my choise. But i want to hear your opinions, because i don't' basically know anything about this stuff (besides the basics). Watercooling solution can be acceptable but i'm on a budget here so i can't afford more then 50-100 € (approx. 65-135 USD) Here's my setup:
CPU: Intel core i5 4670k
MOBO: AsRock Z87 PRO3
GPU:  MSI GeForce GTX 750 Ti
RAM: Kingston HyperX Fury red 2x4GB
PSU: Corsair CX430W V2
SSD: Crucial 128GB M550
HDD: Seagate barracuda 1TB
CASE: Phanteks Enthoo Pro
P.S. I have not bought any of this stuff yet, because i want to get all the parts listed first.
Thanks!
Its only game, why u heff to be mad?
https://linustechtips.com/topic/192989-cpu-cooling/
Thanks!
Corsair hydro series: http://www.corsair.com/en/hydro-series-h100i-extreme-performance-liquid-cpu-cooler
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2615962
Thanks!
i am using the xigmatek Dark knight II with my 3570k and can do a 4.5 overclock with stress testing reaching about 80c with ambient room temp of about 21.1c
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2615970
You might want to look at NZXT Kraken series. X41 reaches about the same performance as an h100i with stock fans.
CPU: I7 4790 @ 4GHz /w Cooler Master Hyper 412S | MOBO: ASUS Z97 PRO | GPU: Gigabyte gtx 780 OC | RAM: Kingston HyperX Fury 16GB @ 1866MHz | PSU: Corsair RM850 | SSD Kingston HyperX 3K 240GB | HDD: WD Blue 1TB 7000rpm | CASE: Phanteks Enthoo Pro | MONITOR: Samsung S24D300 | KEYBOARD: CMStorm Devastator | MOUSE: Logitech G500s | MOUSE#2: Logitech M500| HEADSET: Logitech G230 | SPEAKERS: Logitech Z313 2.1  | Phone: Galaxy Note II
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2615981
NZXT Kraken line or the Corsair Hydro line (H80i, H100i, or H110).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2615993
A Corsair H100i or NZXT Kraken would do a fine job for OCing but make sure you good enough space to mount it properly.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2616239
I would try Nzxt, getting real tired of the super noisy h100i.
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2616593
Well good air cooling performs the same as AIO's (all in one water coolers), they are cheaper, more
Reliable and MILES quieter.
So yeah I would say get a NH-D15/D14 or U14s as your ram may be too high for them other 2.
However if you wish to watercool your GPU get an expandable AIO like the H220.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2616852
NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken NZXT Kraken
Do it. Corsair coolers aren't bad but please for the love of god do not ever install Corsair Link. It is absolutely horrible. NZXT CAM is much much better.
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2616872
The Noctua or Nzxt series might do it for me, but what do you guys/girls think about the Cryorig R1 Ultimate?
Inb4 never heard of it don't buy it mantra.
Dude that cooler looks baller. Would go for it.
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2617513
So you're suggesting it or telling me not to buy it? O.o And yeah thats pretty sick looking cooler
I'm telling you to buy it. Everybody else would probably disagree, cos they are bad.
Buy it. It looks amazing and would perform pretty decently.
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2618976
Thanks!
Honestly for your budget range I'd suggest either a Corsair H100i or a Corsair H105. Honestly I'd go with the H100i just because I personally don't find much of a difference between the H100i and the H105. But hey what do I know? I run a custom watercooling loop so take my advice with a pinch of salt
  • CPU:  AMD Ryzen 7 7800X3D
  • Motherboard:  MSI PRO B650M-A WiFi
  • RAM:  G.Skill Trident Z5 RGB 32GB (2 x 16GB) DDR5 Memory @ 6000MHz
  • Graphics:  Colorful iGame GeForce RTX 3070 Ti Ultra W OC 8G-V
  • StorageKingston KC3000 2TB M.2 PCIe NVMe Gen4 SSD; Seagate Barracuda 2TB Hard Disk Drive @ 7200rpm
  • PSU:  Cooler Master V1000 1000W 80+ Gold
  • Case: Corsair 4000D Airflow
  • Keyboard: Cooler Master CK550 RGB Mechanical Gaming Keyboard w/Gateron Red switches
  • Mouse: Glorious Model O- Wireless @ 1600dpi, 1000Hz
  • DAC: JDS Labs OL DAC
  • AMP: JDS Labs O2 AMP
  • Headphones: Hifiman HE-400I w/ZMF Ori Lambskin pads
  • Soundbar: Creative Sound BlasterX Katana
  • Monitor 1: BenQ EL2870U @ 3840 x 2160, 60Hz
  • Monitor 2ASUS Predator XB252Q @ 1920 x 1080, 240Hz
  • Monitor 3AOC G2460 PQU @ 1080 x 1920, 144Hz
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2622509
H105 has a 38mm thick rad v H100i 27mm thick rad.
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2624797
Those two aio's are way too expensive for me, only retailers here in Finland are selling the over 120 euros, you see. I think i'll get the Cryorig air cooler because it's under 100 euros and performs like a champ. I might go for the Corsair aio's in the future tho.
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2624854
I didn't see much difference in temps from people who have used either
Ah you are in Finland. In the US and Europe they are well under 120 euros
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2625000
Yeah, that is one of the downsides living here. Almost everything is overpriced, because of the shipments from US/Asia to here and the taxes. Taxes are everywhere!!
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2625257
Hardware stuff is actually fairly cheap where I live compared to other Asian countries but it's more expensive than US so...
https://linustechtips.com/topic/192989-cpu-cooling/#findComment-2625265
