Hello, I have a amd system that has recently been causing me to pull my hair out...
Just some specs first:
-Windows 7 home
-AMD Phenom 1045t, Running at (regular clock) 2.7ghz
-MSI 970A-G46
-16GB DDR3 Memory running at 1333(stock settings)
-500GB Hitachi Deskstar, ( It tests good, BTW)
-Nvidia GTX 480, With aftermarked liquid cooler, (AIO Cooler from arctic)
-1000w psu
So here are my problems...
1: I can be doing anything, anything at all, and it will bluescreen, with the error being memory related, (memory tests good) or something about a process delay not recieved (dont remember exactly, Will update when it happens again)
2: Ocasionally it will not post, and give me a memory/ VGA error. I can however make it post by pressing reset, and then it works fine.
3: Java crashes repeatedly, on youtube videos, minecraft, any java game, without leaving me any idea of what happened, the windows will just close. I have tried different versions of java, uninstalling and re-installing, all that, but nothing works. I do believe that this is related to whatever is causing my bluescreens.
If anyone has any ideas on what I need to do, please let me know.
Thanks
-Alex
Sounds like a GPU problem. The mem issue may not be your ram, but your GPU vram.
Try to test different driver versions. What are you currently using?
This actually sounds like a possible problem...
I bought the 480 used, and put the aftermarket cooler on it, I will check the heatsinks on the memory, maybe one fell off....
I used to have problems with BF3 running like crap randomly, but a different driver would fix it for a day or so, but it would eventually get worse. I completely forgot about that..
I will check my videocard and post some updates!
