I have windows 7 pro, and sometimes, i don't know why, i can't click anything. If i have chrome open i can click chrome tabs and stuff but i can't click anything in explorer(not the browser)
why is this, how do i resolve this, if possible i don't want to reinstall cause downloading all my software takes forever even with a 80mbps down network.
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/19189-windows-7-click-problem/
Which mouse are you using?
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/19189-windows-7-click-problem/#findComment-225896
i know for a fact that it's not the mouse. i have used a logitech g700s, razer mamba 2012, razer deathadder 3.5g and a wacom bamboo create tablet
https://linustechtips.com/topic/19189-windows-7-click-problem/#findComment-225988
I have a reason for asking that. Since you use a Logitech G series mouse you probably use the Logitech Gaming Drivers. Just a couple of days ago i had about the same problem with them, tho after crash because of unstable overclock.
In this case it usually helps to close the LCore.exe in the taskmanager.
Maybe that helps.
https://linustechtips.com/topic/19189-windows-7-click-problem/#findComment-226046
as i stated. its not the mouse or the drivers fault. this happened while i was using my original deathadder and mamba mice. i got my logitech mice after the problem occured thinking it was the mouse. it clearly isnt. so i need to know if anybody knows what the issue it.
https://linustechtips.com/topic/19189-windows-7-click-problem/#findComment-226228
Try re-installing the drivers, the other option is to run the registry scanner in Ccleaner and delete any registry keys that it shows to delete.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/19189-windows-7-click-problem/#findComment-226378
Did you manipulate the explorer.exe in any way? Like applying 3rd Party windows themes?
Is your Windows up to date?
PS. Never mind that about your theme, just read in the other thread that you use vanilla aero.
https://linustechtips.com/topic/19189-windows-7-click-problem/#findComment-226391
