I feel like a noob asking this, but I wanna clean the front dust filter on my 690III, and since I didn't build this PC myself, I don't know how to remove the dust filter. Can anyone who owns this case tell me how to remove the front panel and remove the dust filter?
https://linustechtips.com/topic/190686-cooler-master-690iii-front-filter/
If it's anything like the 690II then you just pull the front panel off from the hole at the bottom and vaccum it down.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
I looked on cooler master's website and the pictures appear to show a setup like my haf 912.  If that is the case you have to take off both side panels.  Along the front inside edge there will be three tabs on each side (top, middle, bottom).  You have to carefully press these in and the front will slowly pop off.  Then either vacuum off the dust or hit it with compressed air.
Ah yeah, it's not really a hole, but you can lever it off that way. The top part should have some tabs along both sides that can be taken off when the front is off. (that's with the 690II)
edit:
A quick google would have got you this video though:
https://www.youtube.com/watch?v=cEu_HL77KfI
:P
