I've seen this quite a bit now on the forum. People will recommend a mouse to a new buyer because "it's laser" or because "it's optical", but they refuse to explain why that makes the mouse better or worse.
I've been using a G700s and a Naga 2014 for a while now, and I would never recommend one or the other for having better tracking. They're basically identical in practical usage scenarios.
So what circumstances or conditions make either laser or optical tracking the better choice, or what makes one sensor better than the other when DPI isn't a factor?
Git Gud.
https://linustechtips.com/topic/190207-optical-vs-laser/
Optical would technically be better as it does not have native acceleration which laser mice tend to have however it cannot run at crazy speeds, (hence why logitechs new mouse uses an accelerometer to work out if the mouse is still moving if you move too fast for the optical sensor)
Laser mice support higher DPIs and track better over more surfaces (for example logitechs darkfield laser)
(afaik)
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561822
you are going to start a fanboy war here.
Personally Optical>Laser all day long. If you are FPS gaming you really want an Optical as there is no acceleration or "guesswork" involved that the lasers do. Meaning more accuracy and more predictability to where you are aiming and where you think you will be aiming.
People moan about the lack of "crazy high DPI" settings that opticals don't have that lasers do but if you are playing your FPS games at anything over 1000DPI you are doing it wrong.
Quack 🦆
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561828
(afaik)
Does that native acceleration make a big difference, though? I haven't noticed it with my gear, but it may be a lack of experience...
Git Gud.
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561834
An FPS game at under 1000DPI on a high res screen LOL you'll need like 2 feet of mouse surface.
I can't run DPI lower than 2000 for any game because of my grip and space constraints lol
I should be able to move the pointer from one end of the screen to the other with only a few millimeters of finger flex as far as I care...
but that's just my preference.
Git Gud.
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561851
Yes its like night and day. Will take you a few days to adjust though. (with gaming)
I've been planning to get a G402 since the announce. I guess I'll have to put all the fanboyism to the test, eh?
Isn't there also hard vs soft mouse mat theory based on your sensor? That would be good to know before I get one.
Git Gud.
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561870
What DPI you use on desktop doesn't matter. I use 5760x1080p and I run 1800dpi and I can manage to move my cursor to left to right with a few cm of moment.
In game you should be turning up your in game sensitivity by all means but not the mouse (for optical or laser) after a limit of DPI the mouse (varies per sensor) will start to do more of the guesswork and being less precise. The top CS players use somthing like 150DPI for the mouse but turn up the in game mouse settings.
Give it a shot (no pun intended) I can almost guarantee you will play better.
edit - I am not being a fanboy its just fact.
Quack 🦆
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561876
I use a large desk mat as my glass desk is cold always so it keeps me warm haha. I dont think it matters what surface you use Mine is soft.
Quack 🦆
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561888
(afaik)
You're absolutely right.  Just switched from an optical(Logitech G300) to a laser(Corsair Vengeance M65) recently.  The laser is great, however I have noticed more inaccuracies when using the laser mouse, as opposed to my old optical mouse.  You won't notice the difference until you play games where you need to be exceedingly accurate though, like CS:GO.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561892
No worries, I wasn't calling anyone out for fanboying. I just know there's tons of it behind most recommendations and I want to see it for myself.
Also I only play shooters on occasion, my application would usually be moba games, but the principle should still be the same.
Thanks a ton for explaining it all :D
Git Gud.
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561894
no problem.
(I am a Razer fanboy but shhh!)  :ph34r:
Quack 🦆
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561914
(afaik)
That is true on a general basis... and then there is the G502, a mouse that, for all intents and purposes, uses an optical sensor. It includes DPI settings so high that no sane human would come close to maxing it out (12000 DPI, and no that is not a typo).  As much as I like Logitech, this design choice makes no sense.
Read the community standards; it's like a guide on how to not be a moron.
Gerdauf's Law: Each and every human being, without exception, is the direct carbon copy of the types of people that he/she bitterly opposes.
Remember, calling facts opinions does not ever make the facts opinions, no matter what nonsense you pull.
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561916
Soft is better for maintaining accuracy.  It doesn't allow the mouse to move as quickly, giving you more control over your movements.  I personally prefer hard, but that's because I barely move my mouse anyway (1cm or less)
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561917
If you want something heavy to read, here's a couple of great articles:
http://www.overclock.net/t/951894/the-truthful-mouse-guide
http://www.teamliquid.net/forum/tech-support/333648-an-overview-of-mouse-technology
And a good source to check which sensor a certain mouse has:
http://www.overclock.net/t/854100/gaming-mouse-sensor-list
edit: just stumbled upon this slightly updated mouse guide: http://geekhack.org/index.php?topic=56240.0
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561920
So if it's optical but the DPI settings are that high, does it just extrapolate or does it use gyroscopics to compensate for the limitations of the sensor?
Git Gud.
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561954
If i remember correctly that mouse after 4000 or so DPI the sensor starts guessing a lot and just failing in general. becoming very jittery at 12000 (but still acceptable) :
http://www.overclock.net/t/1481639/logitech-g502-proteus-core-gaming-mouse-review-by-ino
Quack 🦆
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561961
If i remember correctly that mouse after 4000 or so DPI the sensor starts guessing a lot and just failing in general. becoming very jittery at 12000:
Ok, then the whole thing about the new tech in the G402 makes sense. Thought it was just pointless drivel about how fast you can move it. Makes a LOT more sense now xD
Git Gud.
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2561987
I have a 27" 1440p screen, i move my mouse about 10cm to get from one side to the other, i use 800dpi, windows sensitivity set to 6/11
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2563559
I run 450 dpi on a mousemat about 1/3rd the size of a piece of paper.
I play FPS games all day
fight me
Edit: this isn't meant to be insulting :P
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/190207-optical-vs-laser/#findComment-2563699
