Razer deathadder
I have had mine for a long time now and I adore it. Fantastic mouse.
Edit: Oh shit White LED. Never mind
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/188559-need-help-with-new-mouse/#findComment-2538826
Razer deathadder
DA comes in white. Check out the counter logic gaming edition.
https://linustechtips.com/topic/188559-need-help-with-new-mouse/#findComment-2539089
Since you'll play fps I'd strongly recommend that you spend your budget wisely on a mouse with a superb sensor.
As of now the g502 is a mouse that cannot be surpassed regarding sensor performance. However the led is only blue. Don't get inferior mice just for a illumination preference.IMO,sacrificing performance for eye-candy is a recipe for disaster
https://linustechtips.com/topic/188559-need-help-with-new-mouse/#findComment-2539306
G502 for me right now. The evga torg x10 carbon is a good mouse too. There the roccat kone pure military. The roccat none xtd optical should be out soon. Either of the two mionix 7000 ice are great. There's the corsair m45.
Idk there's bunches of stuff, would kinda help if I knew your grip style.
https://linustechtips.com/topic/188559-need-help-with-new-mouse/#findComment-2539440
G502
Or Mionix avior,Zowie fk1,steelseries Rival
It depends on your type of grip since different mice accommodate different grips
Oh yea totally forgot about the rival even though I have one. I think the backs a not too square and prefer the DA but I do have a average sized hand if you have a larger one the rival would be better.
https://linustechtips.com/topic/188559-need-help-with-new-mouse/#findComment-2539448
