So my current system is
Type|Item|Price
**CPU** | [AMD FX-8350 4.0GHz 8-Core Processor](http://pcpartpicker.com/part/amd-cpu-fd8350frhkbox) | $174.98 @ OutletPC
**CPU Cooler** | [Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler](http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2) | $29.99 @ Amazon
**Motherboard** | [Asus Sabertooth 990FX R2.0 ATX AM3+ Motherboard](http://pcpartpicker.com/part/asus-motherboard-sabertooth990fxr20) | $169.49 @ Newegg
**Memory** | [G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory](http://pcpartpicker.com/part/gskill-memory-f312800cl9d8gbxl) | $83.99 @ Newegg
**Storage** | [Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd1002faex) | $88.97 @ OutletPC
**Case** | [NZXT Phantom 630 Windowed Edition (Black) ATX Full Tower Case](http://pcpartpicker.com/part/nzxt-case-cap630wm1) | $139.99 @ Amazon
**Power Supply** | [Corsair Professional 750W 80+ Gold Certified Semi-Modular ATX Power Supply](http://pcpartpicker.com/part/corsair-power-supply-hx750) | $129.99 @ Newegg
**Optical Drive** | [Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer](http://pcpartpicker.com/part/asus-optical-drive-drw24b1stblkbas) | $16.98 @ OutletPC
**Operating System** | [Microsoft Windows 7 Professional SP1 (OEM) (64-bit)](http://pcpartpicker.com/part/microsoft-os-fqc04649) | $134.98 @ OutletPC
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | $969.36
 | Generated by PCPartPicker 2014-07-28 19:52 EDT-0400 |
They didn't have my graphics card but it is a 7970 sapphire
So my sapphire is going to have to go back for rma to sapphire, I have no idea how long that will take. So before I send it off I am going to purchase another graphics card so that I wont be without a computer for school and stuff. My thought was to just get another graphics card that will crossfire with the sapphire when it comes back. So I need it to be a two slot graphics card at most and I believe the r9 280X is the card I have to use.
1. Budget & Location
U.S.  around $350 but could be $400. Purchase date in the next month 1/2
2. Aim
To add to my gaming a once I get back the other graphics card.
3. Monitors
I currently have only one eventually I would like to do 2 or 3 but for now just the one.
So my question is what card, what after market card, and other tips for switching card and crossfire.
https://linustechtips.com/topic/188171-crossfire-for-my-current-system/
for the love of science please select plain text in Pcpartpicker.
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
yes you can use the 280X which is a rebrand of the HD7970
when you get back your Sapphire
be sure to clock up a bit higher to match the speed of the 280X
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
ok wich one should I get I believe it has to be no more than a 2 slot for my motherboard. also APrettyCoolWalrus I don't know how to do that but I will look into it.
check MSI,Gigabyte, Sapphire and PowerColor
when you complete your build on PCPartPicker there is a button near the right saying export/markup
press that then select the second option BBCode
