Handbrake batch processing help - Linux
Solved by xXxYOLOxSWAGxXx_420BlazeIt,
Use the CLI version. it is very simple. You could easily write a script to loop through them.
Alternatively you could use ffmpeg. There are lots of GUIs availible, but again the CLI version is simple to use. it is a little more complex than handbrake though.
bill well ·
Posted in Peripherals0 -
3
2
Ha-Satan ·
Posted in Networking2 -
1
Beenlucky1 ·
Posted in Cooling3 -
Biermax ·
Posted in New Builds and Planning10 -
potatonut ·
Posted in Troubleshooting7 -
9
4
play_circle_filled
Latest From ShortCircuit:
