Gaming pc 3300$ help
Go to solution Solved by ItxCrow,
I already finished the List , Don't reply anymore
http://pcpartpicker.com/user/LordCreeper/saved/Pt3H99
This is the link
Hey guys, I'm planning on getting a new pc this summer.
1. Budget & Location :
My budget is around 3300$ (3350 isn't a problem, 3400 is max max) and I live in the netherlands, but I'd like a pcpartpicker link for the US.
2. Aim
I am going to use the pc mainly for gaming, I'll also use it for school stuff and a little bit of video editing. Gaming at 1080p. Max settings and I'd like to be possible to play almost every game.
3. Monitors
I have 3 23 Inch 1080p monitors and I'd like to use them all 3, if not possible tell me.
4. Peripherals
I've already got everything I need, so I only need the Pc itself
5. Why are you upgrading?
I'd really like to game on pc and I need it for school. I've got a laptop now that I bought for 200$ in 2010.
6. Extra:
I'd like to get a watercooler for the pc
I'd also like the same colour combination, not every thing another colour.
I hope you guys can help me.
Thanks, Crow
https://linustechtips.com/topic/186551-gaming-pc-3300-help/
I thought you have the same topic about this?
My current rig for entertainment/gaming: i5 4570 3,2GHz; MSI B85M-E45; ZOTAC GTX760 AMP!; 8GB (2x4GB) by Kingston; Seagate Barracuda 1TB 7200rpm; Corsair 200R, Corsair VS650; Dell U2312HM, Samsung DVD R/W optical drive; CM Devastator; Corsair MM400 gaming pad
https://linustechtips.com/topic/186551-gaming-pc-3300-help/#findComment-2509727
http://pcpartpicker.com/parts/partlist/
 this would be your main pc, im not sure about any peripherals
You haven't actually got any parts listed mate. :D
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/186551-gaming-pc-3300-help/#findComment-2510619
2. Aim
3. Monitors
4. Peripherals
6. Extra:
Thanks, Crow
any color preferences?
https://linustechtips.com/topic/186551-gaming-pc-3300-help/#findComment-2510748
I already finished the build log, Don't reply anymore
What? Thread started at 08:29am and a build log (link would be good) has already been finished four hours later. Heck it takes me that long just to assemble a decent system, let alone decide its configuration and buy the part.
https://linustechtips.com/topic/186551-gaming-pc-3300-help/#findComment-2510998
I got the list, not the build. I used the wrong words
https://linustechtips.com/topic/186551-gaming-pc-3300-help/#findComment-2511015
