Distilled/deionaised water with a biocide.
https://linustechtips.com/topic/186369-best-coolant/#findComment-2507262
You'll want to put this in the water cooling sub-forum.
hehhehhehhehhehhehhehhehhehhehheh SWIGGITY SWOOTY I'M COMING FOR THAT BOOTY hehhehhehhehhehhehhehhehhehhehheh
huehuehuehuehuehuehuehuehuehuehuehue LINIXTEKTEPS R DE BES I LUV LINUX huehuehuehuehuehuehuehuehuehuehue
https://linustechtips.com/topic/186369-best-coolant/#findComment-2507263
sulfuric acid works wonders
nah but for real i'd say distilled water and make sure it is distilled or you might kill your PC
CPU: AMD FX-8120 | CPU Cooler: Thermaltake Contac 30 | Motherboard: GIGABYTE GA-990FXA-UD3 | Memory: Kingston 16GB (4 x 4GB) DDR3-1333 | Storage: WD 1TB | GPU: Gigabyte Radeon HD 7870 | Case: Thermaltake Chaser MK-I | PSU: Thermaltake Black Widow 850W
https://linustechtips.com/topic/186369-best-coolant/#findComment-2507277
distilled  water with a kill coil or a biocide and make sure you don't mix copper and aluminium. Using dye after a month or so the dye will gunk up in the pump and/or possibly your cpu and gpu waterblocks.
 Motherboard - Asus Z97-WS ll Processor -Intel i7-4790K ll Cooling- Custom Loop ll RAM - Corsair Dominator Platinum 16GB(2x8) @2400 ll Graphics Card  - EVGA GeForce GTX 980 TI ll PSU - Corsair AX 1200 Watts ll SSD - Samsung 840 Pro 256GB ll HDD - seagate barracuda green 2TB & Seagate 4TB ll Case - Silverstone TJ11 ll Audio - Asus Xonar Essence STX  ll OS- Win 10 PRO 64-bit ll Keyboard- CM Storm QuickfireTK Green Switchesll Mouse- Logitech G502
https://linustechtips.com/topic/186369-best-coolant/#findComment-2507293
DI water,biocide and half a cap of Kodak Photoflow to lower the surface tensiom
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
https://linustechtips.com/topic/186369-best-coolant/#findComment-2509721
