Specs: i7 4770k, 16GB Corsair RAM, Asus Maximus VI Hero, EVGA 780ti w/ ACX Superclocked, Phantom 410 Mid Tower
I currently have 2 120mm fans (one exhaust and one intake) and one 140mm exhaust fan. My GPU under max load hovers around 78*C, while my CPU around 70*C (coupled with a Cooler Master 212 EVO). Because I plan to overclock eventually, and possibly add another GPU in SLI, I figured it was time to add more cooling.
I plan to add a 140mm intake right next to the GPU (side of the case), a 140mm exhaust out the top of the case (right next to the other 140mm exhaust), and a 120mm intake at the front of the case next to the other 120mm intake. Is this overkill?
https://linustechtips.com/topic/186347-do-i-need-more-airflow/
Not really...
Never too many fans
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/186347-do-i-need-more-airflow/#findComment-2506893
Yes. SLI = hotter GPU's, and 80C won't be cool enough for me. If your GPU's stay at that temp, it would heat up your CPU too. I highly recommend filling up your fan slots with premium fans. Most stock fans are crap.
Your plan would be ideal. There is never overkill when it comes to cooling.
https://linustechtips.com/topic/186347-do-i-need-more-airflow/#findComment-2506900
If you go SLI, then yes add another fan. Don't put in too many fans though or it'll just be unnecessarily loud
CPU: Intel Core i7 4770 | Motherboard: Asus Z97-A | RAM: 8gb (2x4gb) Corsair LP @1600mhz | GPU: Asus TUF GTX 1660 OC 6GB | Case: Fractal Design Define R4 | Storage: 250gb Samsung 840 EVO and 1TB WD Black 7200rpm | PSU: Corsair CX750M | Display: Asus VG245H 1920x1080 | Cooling: Cooler Master Hyper 212 EVO and default case fans | Laptop: Early 2015 13" Macbook Pro Retina - i5 2.7Ghz - 256GB SSD
https://linustechtips.com/topic/186347-do-i-need-more-airflow/#findComment-2506929
i would say add the fans on the front and top but i dont think the gpu one will be worth it, maybe vent the side if you want more, what case do you have
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/186347-do-i-need-more-airflow/#findComment-2507042
No such thing as too many fans, fill her up. With a CPU air cooler in there leave the rear exhaust fan. You could put two good quality fans in the front and a 120mm instead of a 140mm for the side with a direct airflow feature since you're using it to get better GPU temps. The side fan is definitely a good idea when doing SLI. Have a look at your temps with one 140mm in the top first, if you're still unhappy add another one.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/186347-do-i-need-more-airflow/#findComment-2509948
