PC not turning on! help!
Ok last night my PC turned off while i was watching youtube and everything was fine so i turned it back on and it turned on.. didnt think anything abbout it so i go to sleep then i wake up and turn on my PC and it isnt turning on, it turned on once so i put back my system to its spot and re-turned it on and it didnt come on. whats wrong!!!
EDIT: MY PSU IS FINE!! I JUST CHECKED IT WITH THE OL GREEN WIRE/BLACK WIRE TRICK
https://linustechtips.com/topic/186039-pc-not-turning-on-help/
is there any lights on your mobo that are on when the power is turned on at the wall?
CPU: i7 8700k Motherboard: MSI Z370 Krait Gaming RAM: 4x 8GB Corsair Vengeance Pro (2 white, 2 black) GPU: MSI RTX 2070 Armor Case: Corsair Crystal 570x White HDD: 2x 2TB Seagate Barracuda 7200rpm Sata 3 SSD: 240GB Corsair Force 3 + 500GB Samsung 970 Evo Cooling: Corsair Hydro Series™ H150i PSU: Corsair RM750i OS: Windows 10 Pro 64-Bit
Mouse: Logitech G600 Keyboard: Corsair K95 RGB Cherry MX Brown Monitor: Samsung S24C570L 1080p 23.6" + AOC AGON 240Hz 1080p Sound: HyperX Cloud Headset Black/Red + Logitech Z213 Speakers 2.1
https://linustechtips.com/topic/186039-pc-not-turning-on-help/#findComment-2501849
Check the stickie and do whatever it says there. If nothing fixes it then something is probably broken
http://linustechtips.com/main/topic/42440-readme-how-to-respond-to-a-no-post-or-no-power-up-situation/
"You can get more of what you want with a kind word and a gun than you can with just a kind word." -- Al Capone.
https://linustechtips.com/topic/186039-pc-not-turning-on-help/#findComment-2501853
