I need an article or something to explain to a friend how raw GHZ isnt the only way to show how powerful a CPU is. Something explaining Per core performance, cache, ext.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/185767-article-for-explaining-cpus/
This episode of Techquickie does a pretty good job, not an article but it should get the point across.
CPU: I7 3770k @4.8 ghz | GPU: GTX 1080 FE SLI | RAM: 16gb (2x8gb) gskill sniper 1866mhz | Mobo: Asus P8Z77-V LK | PSU: Rosewill Hive 1000W | Case: Corsair 750D | Cooler:Corsair H110| Boot: 2X Kingston v300 120GB RAID 0 | Storage: 1 WD 1tb green | 2 3TB seagate Barracuda|
Thanks!
Like for uz.
This is a good guide for those looking to see what is the best for them.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
You guys rocking it.
Imagine two math-teams.
One of the teams is called Intel-math (haswell)
One of the teams are split into 4 sections (a core essentially). Each section have 4 People to do integer math (full number like 1 & 2 & 3 & etc) and 6 people doing floating point calculations (like 1,2 & 3,14 & etc). Each of these teammembers can do one calculation per cycle. So we could in thoery do (4 + 6) * 4 calculations per cycle (most unlikely you find software that can utilize all that).
So team intel can do 40 calculation per cycle.
The other team is called AMD-math (piledriver)
This team is splitted into 4 sections (CMT cores (what AMD calls a module)). These sections are then split into 2 smaller sections (ALU cluster, essentially what AMD calls a "core"). This "mini-sections" have 2 people doing integer math. Both these "mini-sections" are sharing the floating point squad which consist of 4 people. So in theory it could make ((2 * 2) + 4) * 4 calculations per cycle.
So team AMD can do 32 instruction per cycle (in theory).
This is a VERY simplified version of how CPU works. And we are NOT considering ISAs that can help on certain task (which have a VERY big role in a CPUs performance).
Just a thought, in the west, we use the period where you guys use the comma and vice versa.
Your numbers look like this: 3.956.333,296
Our numbers look like this: 3,956,333.296
Weird, I know, but I'm just saying in case you or someone else is confused by that.
Yes, I'm from Europe. So we use commas. You are absolutely right. Good point
So team AMD can do 38 instruction per cycle (in theory).
that math comes out to 32.
EDIT: was fixed.
Software Engineer for Suncorp (Australia), Computer Tech Enthusiast, Miami University Graduate, Nerd
I do apologize. I'm very tired. I do thank you for noticing my mistake, and I have fixed it :)
No problem. I just wanted to make sure this wasn't an incorrectly written equation, because then I'd be more curious.
Either way, AMD is thankfully getting rid of CMT now that Keller is back in the driver's seat.
Yes. I'm sure he will put out a VERY efficient architecture. I think AMD mind is on efficiency instead of direct performance. But I'm very excited about his work.
Now if they could just bring down the wattage needed to run their CPUs and GPUs,..
They will. They most definitely will. If they don't, they will be out of business.
If the 295x2 is any indication, I weep for AMD's future lol.
