So like a week ago i bought an ssd, installed it and everything, reinstalled windows 8 everything was going great, installed cs go, boom i had massive fps drops from 250 fps right to 50 fps when shooting, when before i was constantly on 200/250...but i let that one pass becasuse maybe it was the new update, since i was doing great on every other game, but now, i just reinstalled my graphics card because i had to do something on my rig, and now i just get 50 fps on cs go all the time! and were before i had 80 fps on borderlands 2 i now only have 30/40 fps! i have no ideia wth is this...i need help....any help is apreciated
Rig in signiture
CPU: Amd fx 8120 3.9ghz...Motherboard: Asus m5a97 evo R:2.0...RAM: 8gb 1600 kingston hyperx blu...GPU: XFX R9 280x ...CASE: Nzxt h440...
HDD: Kingston adata ssd 500 gigs, wd blue 500gb...PSU: Corsair gs700...Monitors: Asus vk222h Cooler: Noctua nh-d14...Keyboard:coolermaster masterkeys m...Mouse: logitech g300...Headphones: Logitech g430
https://linustechtips.com/topic/185667-help-fast-please/
Did you installed the drivers properly? Try other driver version is not.
Is V-sync on or off ?
Do you have Nvidia Experience enabled? That thing can mess with your settings.
Are you sure you have DX and everything updated?
huuh its amd, sorry rig is in the signiture, aand yes i tried all of that
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496703
are you sure you have the latest stable drivers?
tried the latest beta and the non beta, same
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496706
Do you have V-Sync on or off?
Also are you using a BETA Driver???
But it sounds like V-Sync.
That can really mess you up sometime, I had experience with a games frame rate fluxuating because V-Sync
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496714
nope, always play cs with minimum settings for best fps, meaning everyting off
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496721
Re-Install CSGO
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496726
Re-Install CSGO
tried it several times
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496730
btw, i 10min ago i changed my cpu thermal paste if that matters
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496737
Okay create a CSGO Shortcut to your desktop.
Right Click > Properties > Target > "C:\Users\<user>\Programs Files (x86)\Steam\SteamApps\Counter Strike Global Offence\Whateverthelaunchfileis" (the directory should look something similar to that) > No beside the quote do a space and then type "-norestrictions" (without the quotes)
Should look something like this ....  "C\Users\<user?\...\Counter Strike Global Offence\something.exe" -norestrictions
Click apply, then launch the game with the shortcut.
If it still doesnt work just delete the shortcut you made and edited.
Tell me if it works then and I will tell you how to make steam launch it with that shortcut for now on.
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496774
Nah tempatures should have nothing to do with this, to me it sounds like a drivers issue.
Did you try resetting all the games graphic settings back to default.
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496782
if none of that works try installing a the drivers manually off of nvidia's site. Who knows it might be the way GeForce Experience is installing the drivers.
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496790
i'll try it
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496794
its an amd hd7850
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496796
nope that doesnt work
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496801
What are the temperatures on the CPU?
40 idle 60 full load
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496807
its an amd hd7850
oh then download the drivers manually off of AMD's site.
(im not very famaiuar with how amd cards work soo)
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496809
Well that's decent. About what I get.
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496815
i always install them manually thats the thing :|
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496833
yeah i have a nh-d14 idk if those are good considering i have a fx8120
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496841
Hmm not sure if AMD has a thing like Nvidia has GeForce Experience where it will install the drivers for you. if so download that and see what happens.
But yeah I put 20 dollars on saying its a drivers issue.
Also when you launch CSGO go into your video settings their should be a button somewhere saying set to default settings click that, apply, play for about 5 minutes and see what happens.
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496855
so i reinstalled my drivers that, seemed to up me to100fps in cs go but still thats pretty far from 200/250
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496860
amd has a software that detects your gpu and finds your drivers for you, downloads it and then installs it
https://linustechtips.com/topic/185667-help-fast-please/#findComment-2496871
