I have an air conditioner that turns on but then after a couple of minutes, it turns off and turns off the electricity of the room its in.
This is the AC;
I've tried running it with an extension cord to another outlet but after a couple of minutes, its gone, This AC worked for a couple of summers when we first moved in. My dad said that the fuse is done for and that's whats causing it.
Anyone know whats wrong??
There are 10 types of people in this world, those who understand binary, and those who don't.
https://linustechtips.com/topic/185311-help-needed-w-air-conditioner/
sounds like a short internally which can trip the circuit breaker
time for a new AC bro
newer ones are power efficient
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
