Hey,
I shut down my pc and disconnected the power from it. But when I connected it again it cannot make a connection to the web acces. Its stuck at identifieng for a long time and then it sais it has no internet acces. I tried setting up a static ip but that didn't work, I also reinstalled my drivers but that didn't work either.
Oh I also switched cables on my switch but that didn't help either.
I've had this problem before (with another pc) about half a year ago but I cannot remember how I solved it back then.
When I connect my pc with another cable from another switch everything works fine...
My ipconfig:
Windows IP-configuratie    Hostnaam  . . . . . . . . . . . . : Whiplash   Primair DNS-achtervoegsel . . . . :   Knooppunttype . . . . . . . . . . : hybride   IP-routering ingeschakeld . . . . : nee   WINS-proxy ingeschakeld . . . . . : nee Ethernet-adapter voor LAN-verbinding:    Verbindingsspec. DNS-achtervoegsel:   Beschrijving. . . . . . . . . . . : Intel(R) Ethernet Connection (2) I218-V   Fysiek adres. . . . . . . . . . . : 40-16-7E-AE-6F-07   DHCP ingeschakeld . . . . . . . . : ja   Autom. configuratie ingeschakeld  : ja   IPv6-adres. . . . . . . . . . . . : 2001:981:932e:1:64eb:4f4b:44cd:139e(voorkeur)   Tijdelijk IPv6-adres. . . . . . . : 2001:981:932e:1:50b8:61bc:59b0:c60a(voorkeur)   Link-local IPv6-adres . . . . . . : fe80::64eb:4f4b:44cd:139e%10(voorkeur)   Automatisch geconf.IPv4-adres . . : 169.254.19.158(voorkeur)   Subnetmasker. . . . . . . . . . . : 255.255.0.0   Standaardgateway. . . . . . . . . : fe80::9ec7:a6ff:fe02:7753%10   DHCPv6 IAID . . . . . . . . . . . : 239081086   DHCPv6-client DUID. . . . . . . . : 00-01-00-01-10-ED-E0-D9-40-16-7E-AE-6F-07    DNS-servers . . . . . . . . . . . : fd00::9ec7:a6ff:fe02:7753   NetBIOS via TCPIP . . . . . . . . : ingeschakeld
I'm sorry its in Dutch but you might be able to figure it out :(.
Thanks in advance.
Build log "Whiplash" : http://linustechtips.com/main/topic/158477-the-hero/
Whiplash: 4790k@4,4Ghz|Maximus VII Hero|4x4Gb Red/Black HyperX fury 1866Mhz|R9 290 Tri-X|Modded 450D|Sleeved cables on a M12II evo 850W|M500 480Gb| BenQ XL2411T@144Hz
Laptop: 4700MQ|16Gb@1600Mhz|Quadro 1100M|1080P|128Gb SSD|500Gb 7200RPM hdd
https://linustechtips.com/topic/184442-network-problem-identifieing/
Windows IP-configuration    Hostnaam  . . . . . . . . . . . . : Whiplash   Primair DNS-achtervoegsel . . . . :   Node type . . . . . . . . . . : hybride   IP-routering enabled . . . . : no   WINS-proxy enabled . . . . . : no Ethernet-adapter for LAN-verbinding:    Connectionspec. DNS-achtervoegsel:   Description. . . . . . . . . . . : Intel(R) Ethernet Connection (2) I218-V   Fhysical adres. . . . . . . . . . . : 40-16-7E-AE-6F-07   DHCP Enabled . . . . . . . . : yes   Autom. configuration enabled  : yes   IPv6-adres. . . . . . . . . . . . : 2001:981:932e:1:64eb:4f4b:44cd:139e(voorkeur)   Temporary IPv6-adres. . . . . . . : 2001:981:932e:1:50b8:61bc:59b0:c60a(voorkeur)   Link-local IPv6-adres . . . . . . : fe80::64eb:4f4b:44cd:139e%10(voorkeur)   Automatic geconf.IPv4-adres . . : 169.254.19.158(voorkeur)   Subnetmask. . . . . . . . . . . : 255.255.0.0   Defaultgateway. . . . . . . . . : fe80::9ec7:a6ff:fe02:7753%10   DHCPv6 IAID . . . . . . . . . . . : 239081086   DHCPv6-client DUID. . . . . . . . : 00-01-00-01-10-ED-E0-D9-40-16-7E-AE-6F-07    DNS-servers . . . . . . . . . . . : fd00::9ec7:a6ff:fe02:7753   NetBIOS via TCPIP . . . . . . . . : ingeschakeld
I can't help you with your problem, sorry but i translated the Dutch to English ;) It is easier for the others who don't speak Dutch.
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
I dont think you have IPv4 Enabled, Try enabling it.
You can also try :
Ipconfig /all
ipconfig /renew
/ipconfig /flushdns
Edited by William12h
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
Try running this in an elevated command prompt: netsh winsock reset
Also check your Windows log-files (right mouseclick on Computer, Beheren, Logboeken, Windows logboeken, Systeem) to see if there is any IP-conflict. If you click on Niveau, you can sort them on level (Kritiek, Informatie etc) and see if there is any networkrelated trouble there.
Sorry for the non-Dutchspeaking people, I explained the Windows-thingies in Dutch, because I saw that he uses Dutch Windows 7
Currently working on a Watercooled Corsair Obsidian 350D (clicky)
Intel i5 4670k, ASUS GTX 780, Samsung 840 Evo, 16GB RAM, 3 TB Seagate HDD
You can also try :
Ipconfig /all
ipconfig /renew
/ipconfig /flushdns
Ipv4 is enabled, and I already tried all of the above. But it did not work... :( But thanks for helping out.
It might be your router/switch messing with your connection then.
Do you happen to have DHCP Reservations enabled?
Nope. :( But also thanks for helping out.
"netsh winsock reset" doens't help either ;(. No Ip-conflicts in the logs. Only a couple of "Network link is disconnected" warnings from when I pulled out the cable to use the other one coming from the other switch :(
I'm going to think about it for a bit, maybe I remember what I did last time to fix this :) and I'll have antoher look tomorrow after work.
Again thanks for trying to help :)
