Enough Power?
Go to solution Solved by dragoon20005,
Hello, I was wondering if anyone knows if a 750 Watt Powersupply is enough to Power this rig - http://pcpartpicker.com/p/zccNxr
According to PC part picker it will give me a ~50 watt extra, If I go for Duel 780 Ti's. Will the 50 Watts be enough to OC Both GPU's, and the CPU?
Apologize if some people think this is in the wrong section.
will be pushing it and OC will draw more watts than you expect
pick 800-850 watts
that is if you chose to SLi
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/182802-enough-power/
pick 800-850 watts
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/182802-enough-power/#findComment-2456847
My 750 does fine at a pretty similar set up. Go RM1000 if you're really worried and want SLI.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/182802-enough-power/#findComment-2456856
pick 800-850 watts
Thanks man! Uped it up too 850 Watts!
sex hahaha
https://linustechtips.com/topic/182802-enough-power/#findComment-2456883
