What about the difference between Z97 and H97? :)
Z97 is when you need SLi and OC for your K series chip
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456829
Z97 has overclocking features and more boards fully support SLI and crossfire, they have some more features but they are not required for most users, if you go with a locked CPU (non ''k'') then you should not consider a Z97 board they cost more.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456836
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456897
The Asrock board is superior, it can use 4 DDR3 sticks and is just plain better all around, i'd go with that.
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456915
^^  :huh:
nanosuit
both board can fit 4 DIMMS
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456925
^^  :huh:
nanosuit
nope, this is the gigabyte in question, the link clearly showed me we are talking about the GA-H97M-HD3:
http://www.gigabyte.com/products/product-page.aspx?pid=4965#ov
very cheap...
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456934
nope, this is the gigabyte in question:
very cheap...
oh...
i was looking at this version
http://www.gigabyte.sg/products/product-page.aspx?pid=4971#ov
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456939
oh...
this is the D3H, it's much better...but the op linked the HD3...same letters in a different order to confuse buyers...i hate it when they do that!
For that reason i recommanded the Asrock with is superior to the HD3 but not to the D3H (wich was not an option)
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456948
me too
much worst than MSI old naming
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2456958
The Ram i have choosen is :http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16820231460. will the Asrock mobo support this Ram???
sure, if you want it running at 1866mhz remember to enable xmp profile 1 in the bios otherwise the ram will run at 1333mhz stock.
stands true for every motherboards you always have to enable xmp profile in order to run the ram at rated speed.
Quote:
Support for Intel XMP Intel Extreme Memory Profiles (XMP) technology provides a robust, profile-based overclocking solution for novice and experienced overclockers. Easily overclock your platform by selecting the predefined profile in the BIOS, or manually adjust the frequency and timings to extract the maximum performance from your system.
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2457173
But when they write supported speeds i thought the 1866 wouldn't run??
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2457188
it says on asrock website that it supports 1600mhz but the board should take 1866mhz without issues, if not just run the ram at 1600mhz but i'm 99% confident that if you pick XMP profile 1 it will run at 1866mhz all day long.
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2457224
Hey there!
You are talking about some serious gaming? I helped my mate upgrade his PC and he can nope run BF4 on high graphics ;). I would suggest 16GB of ram, just because its cheap before the DDR4 ram is coming out and to be safe, spent a little extra and upgrade. You want a pretty decent GPU because thats what will do the majority of your video rendering. So, I would go with a Asus board, XMS3 ram ( 1600MHZ 16GB ), DVD Burner, i5 non unlocked core, if you are a over clocker get the unlocked K, and SSD for boot + WD Black for data. Ill make a list and link down the bottom of the system I would build you. For high end gaming you are looking at $2000 - $3000, especially with the way everything is increasing. Hope this helped
- Sam Palmer
System: Little less ( Maybe Medium Settings ) http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=241816&action=wish_lists
              More Cash ( High Settings ) http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=242133&action=wish_lists
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2458010
Hey there!
- Sam Palmer
everything said there is pretty much wrong mate...an high end gaming rig won't cost nowhere near 2000$-3000$...and you don't need 16gb of ram for gaming as no games as of today ever used more than 5GB of RAM (OS and apps running in the background included!) ...video rendering is done by the CPU in 90%+ of the softwares, RAM speed has no effect on gaming either...here to prove you that you're wrong a full unleashed gaming PC that can run anything you throw at it on ultra settings at 1080P with constant 60+FPS:
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($210.00 @ NCIX US)
CPU Cooler: be quiet! Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler  ($64.99 @ NCIX US)
Motherboard: MSI Z87-G43 Gaming ATX LGA1150 Motherboard  ($109.79 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($82.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($54.99 @ Amazon)
Storage: Western Digital RE3 1TB 3.5" 7200RPM Internal Hard Drive  ($48.24 @ Amazon)
Video Card: PowerColor Radeon R9 290 4GB TurboDuo Video Card  ($322.00 @ Newegg)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($24.99 @ Micro Center)
Power Supply: Cooler Master VSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Total: $966.98
See that?
full gaming tower with SSD, 1TB, 8GB of RAM, high-end 4GB GPU, unlocked haswell CPU, great silent CPU cooler, great gaming motherboard with tons of cool features...Gold rated semi-modular PSU...all that for less than 1000$ ;)
https://linustechtips.com/topic/182783-motherboard-help/page/2/#findComment-2460120
