Hey, I am making a new pc and will be using the BitFenix Prodigy Mini-ITX.
Pc will be used for playing and school. Games like WoW and that kind of stuff, so there is no need for Titan graphics card.
I am new to making small case builds/budget builds.
If people can recommend some or all the parts for the build that would be greatly appriciated.
Remember I will be using the BitFenix Prodigy Mini-ITX
Thanks for all the help in advance
https://linustechtips.com/topic/182207-small-pc-budget-pc-build/
Budget? plox
https://linustechtips.com/topic/182207-small-pc-budget-pc-build/#findComment-2447993
