I have gigabytes z87x-ud3h board and I went to update the bios from f7 to f9 via Gigabytes @BIOS software. After I did it I rebotted and when it got done with the starting windows screen it immediately went to windows error screen where I could either start windows normally or start system recovery. I decided to launch system recovery and everything was fixed. How do I got about installing my old bios which I have saved on the desktop and then updating it again hopefully with no errors?
https://linustechtips.com/topic/180792-help-resetting-my-bios/
I have gigabytes z97x-ud3h board and I went to update the bios from f7 to f9 via Gigabytes @BIOS software. After I did it I rebotted and when it got done with the starting windows screen it immediately went to windows error screen where I could either start windows normally or start system recovery. I decided to launch system recovery and everything was fixed. How do I got about installing my old bios which I have saved on the desktop and then updating it again hopefully with no errors?
When you update your BIOS, all the settings will be reverted back to Default / Auto. You may just need to set everything back to what it was.
Something right off the top of my head...IDE mode or AHCI mode for the SATA ports.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/180792-help-resetting-my-bios/#findComment-2427914
I have the same mobo but cant remember where the pins to touch with a screwdriver are, i have done it before
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/180792-help-resetting-my-bios/#findComment-2427924
I dont know which one IDE or AHCI
https://linustechtips.com/topic/180792-help-resetting-my-bios/#findComment-2427937
Look at mobo manual for reference. On mobo PCB, there are two switches. One switches from main BIOS to secondary. There's also button next to start and reset ones to clear CMOS. Remember to shutdown pc and flip PSU switch before doing that. (I had to check my own manual for this :P)
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/180792-help-resetting-my-bios/#findComment-2431878
