First build/heating issues
Solved by Akolyte,
keep your pc off the floor and keep the dust filters in, when you dont have much dust removing the dust filters can be good but in your case, keep them in.
In the way of your temps, they are fine, my 4670k runs at 55c during gaming on its overclock (4.2GHZ, 1.2V) even that is perfectly fine. I would say once you reach 75-80 cpu temps thats a problem. 85c is quite hot for a gpu, but if it doesn't go anything above that, I guess its okay.
