So I just built a gaming PC in the 750D with a fully modular PSU, and my cable management looks like absolute crap. I'm really unhappy with it. I think one of the reasons it looks so bad is because I had to use three SATA cables, one for each drive because I couldn't plug more than one drive into one SATA cable. Anyways, what do I do? I'm really unhappy with it right now.
Edit: I don't have a GPU yet, but when I do, it should be the GTX 780Ti or better.
https://linustechtips.com/topic/179849-750d-cable-management/
Use the cable management grommets and ties...
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416123
Yeah, get some pics and tag me so I can help. I'm OCD with my cables.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416153
The way that works for me is bundling together either cables that are running to the same location or cables that are similar to each other, and then strapping those to the chassis. But that's just how I do it.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416171
I hate to say it, but it might be worth it to take it all out and redo it. Use twist ties, and put the 24-pin through the hole that's above where it is now. Then see what it looks like. If you can't get it to look better than my old computer (in the spoiler below) we have to talk. Granted, I have less cables, but I have to deal with no real cable management and IDE cables.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416435
I don't know how I should tie anything and where it should go. It's hard to hide the cables of the H100i because of so many things to plug into the front.
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416471
If you could give us a better, wider picture of the inside, that would help.
You'll have to re-do it I'm afraid, but first buy some extension wires, ebay has MANY different extensions out there, and use as many zip ties as you can, once again, Ebay is your friend.
Also, you could look around YouTube to see how they have done their cable management to get a few ideas.
PC SPECS: AMD FX-6300 @ 3.5Ghz (CPU) || MSI 970A-G43 (MB) || 8GB Crucial Ballistix Sport 1600Mhz (RAM) || MSI AMD 6870 1GB (GPU) || Aerocool 6th Element (CASE) || Sandisk 64GB SSD + Seagate 500GB HDD (STORAGE) || XFX 550w Pro Series (PSU) || ASUS MX239H 23" (MONITOR) || Arctic Cooling Freezer 7 Pro (COOLER) || Logitech G110 (KEYBOARD)
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416481
If more than one cable is going to the same spot, get some twist ties and tie them together. Maybe put the H100i cables through where the 8-pin EPS connector goes if the cables are long enough. I wish I could just poof to your house and do it for you. :(
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416497
Me too.
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416500
How about I get those ties that you cut off the extra when you pull the tie together enough?
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416505
Me too.
If I can do that well with IDE crap and a non-cable-management-friendly case, imagine what I could do with the proper "equipment."
Those are a pain in the butt if you ever have to redo the wires or remove one. I wouldn't recommend it personally.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416508
I can't use a twist tie to save my life.
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416519
How can't you use them?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416524
Cant wait to see this :D
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416613
See what?,
Cable management pics ;) If you cant tell I love cables :D
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416624
I'm going to get cable ties and redo it all.
Can't wait to see what it looks like, that is if you post pics :)
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416636
After I'm done with the cable management?
Yeah :) or you could do before and after pics ;)
https://linustechtips.com/topic/179849-750d-cable-management/#findComment-2416719
