Hi!
I have an offer to get Asus HD 6870 graphics card for really cheap price (http://www.asus.com/Graphics_Cards/EAH6870_DC2DI2S1GD5/). Card is fully working, without any problems, I have tested it on sellers computer.
Problem is, that I have HD 7770 now, and it is not so power hungry and need only one PCI Ex 6pin connector.
My PSU is Chieftec iArena GPA-500S8 with two 12v rails (24A and 21A).
By this http://www.tomshardware.com/reviews/power-supply-oem-manufacturer,2913-5.html my PSU is Channel Well, that is quite good manufacturer from what I can read in web.
But PSU has only one PCI Ex 6pin connector, HD 6870 need two.
I have an adapter 2x4pin Molex to 6pin. Is it safe to use that. if PSU only has daisy chained Molex connectors???
Intel i7 2600 @ 4.2 Ghz | MSI Z77-GD55 | Crucial 16 GB DDR3 RAM 1600Mhz | Intel 330 SSD 180Gb | Western Digital Black 1Tb | Western Digital Green 2Tb | Gigabyte GTX 650 Ti | OCZ ModXStream Pro 500W | Thermaltake Commander MS-I case | OS X Yosemite | Dell Vostro 3550 Windows 10
Intel Xeon 1230 V2 | Gigabyte GA-H61M-S | Kingston 4Gb RAM 1333Mhz | Seagate 1TB  | Fractial Design Arc mini | Windows 10
https://linustechtips.com/topic/179541-molex-to-6pin/
not a good idea to use molex to 6 pin
they have a high chance to melt and catch fire
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/179541-molex-to-6pin/#findComment-2412083
