I need a cpu cooler I was looking at the Hyper 212 Evo I have a 1155 socket so I need a cpu cooler with at 1155 bracket, or should I buy a bracket for my Cooler Master V8?
If you have a V8, I would just buy a bracket for it instead of spending on a new cooler. (http://www.cmstore-usa.com/v8-accessories-kit/) but its out of stock currently. Try contacting Cooler Master to see if they can send you one or tell you when they will restock.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/177107-best-cpu-cooler/#findComment-2376342
The GeminII S524 kit is the same mounting hardware and is in stock :)
Cooler Master USA representing! Looking for help? Head to the CM Fanzone to get in touch with the Customer Support team!
https://linustechtips.com/topic/177107-best-cpu-cooler/#findComment-2385732
Depends on your bucket. For a cheap CPU cooler that does really well yeah Hyper 212 Evo. If you're willing to spend a bit more or you're planning to overclock, I'd highly recommend the Noctua U14S (it whoops the H100i)
"Rawr XD"
https://linustechtips.com/topic/177107-best-cpu-cooler/#findComment-2387268
