XFX Radeon R9 280A-TDFD Problems?
Solved by Electronics Wizardy,
Mostly just games like somehow Garry's Mod. This makes so little sense because of how non-demanding this game is. I am also getting some bad performance on AMRA 3. I get I shouldn't be able to Ultra ARMA, but even on Standard I get 20-25 FPS with drops.
games that are non demanding need good drivers.
Also check for viruses and task manager to check to see if something else is chewing your cpu.
Use a program like msi afterburner to check gpu load when at desktop it should be near 0
If possible do a clean install of just that game and drivers on another drive and that will tell you if it is a problem with your install.
Also switch back to see if using the 630 again improves fps if yes it is drivers
