xfx or cooler master?
Go to solution Solved by SpyRosL,
The only good power supply line from coolermaster is the v series.
I vote for the xfx.
I vote for the xfx.
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/174793-xfx-or-cooler-master/#findComment-2326025
Every xfx PSU is made by seasonic, which is one of the most reliable OEMs in the market. Only the expensive cooler master supplies are seasonic-made
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
https://linustechtips.com/topic/174793-xfx-or-cooler-master/#findComment-2327573
XFX or the Cooler Master V series (only ones I can trust from CM).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/174793-xfx-or-cooler-master/#findComment-2327612
I vote for the xfx.
Harsh. Pending on your region, I'd recommend our GM series! :)
Cooler Master USA representing! Looking for help? Head to the CM Fanzone to get in touch with the Customer Support team!
https://linustechtips.com/topic/174793-xfx-or-cooler-master/#findComment-2332694
Even though the GM series are CWT units, they still don't compare to Seasonic. There is nothing wrong with CWT per se, but they don't offer as clean of power as a Seasonic unit. This was already experienced by Corsair, when they moved from CWT to Seasonic when making the TX series power supplies.
Phanteks Enthoo Pro Black | Corsair TX750v2 | ASRock Z97 Extreme4 | Core i5 4670K @ 4.4 GHz @ 1.27V | Corsair H105 | 16GB Patriot Viper 3 PC3-12800 | EVGA GeForce GTX 770 | Axiom Signature III 240GB SSD | WDC 1TB Blue | Hitachi 750GB
I use a 'moron filter' on tech forums. If I don't respond to your post, considered yourself filtered out.
https://linustechtips.com/topic/174793-xfx-or-cooler-master/#findComment-2332792
