It should do 60 FPS in games.
A single 290x2 can barely handle 4k so what makes you think that 2 of them can handle 3 times the pixels?
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/174750-8000-build-help/page/2/#findComment-2325513
I want a future-proof rig and the price is flexible, I want the best gaming experience possible.
I dont want the most expensive parts, the budget just happens to be a bit luxurious.
No this is not a troll post, I really need help.
Futur proof won't excist. Can you look in the future? If so, please tell me the next numbers for the lotto please!
We don't know what the future will bring and what games will do.
What games do you play? Do you like to play?
The value of your build will drop SUPERHARD. It's better to not spend all your money and just buy a system now that will do just fine and upgrade the GPU's when you need more horsepower.
Anyway, here is my suggestion. Keyboard and mouse is hard to suggest, so I went with brands that I know and love. Ducky keyboards are amazing and Logitech mouse are kickass (personal preference)
http://pcpartpicker.com/p/WMc2bv
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
https://linustechtips.com/topic/174750-8000-build-help/page/2/#findComment-2325876
Save the 3000 to 5000$ and upgrade the video card when it inevitably will be too slow for 4K next year. Since you have made no mention of editing/rendering, you don't need X79.
X79 actually makes sense when you go CF/SLI at higher resolutions.
In some games, there can be increases up to 30% on 5760x1080 resolution. When going from 115x to 2011.
On 2560x1440 it is lower, but still an increase.
https://linustechtips.com/topic/174750-8000-build-help/page/2/#findComment-2326029
