Ther are three tabs that hold the Front panal to the metal part of the case that broke off in shipping and I am wondering what I should do to fix it.
Picture: http://i.imgur.com/C7OjWZt.jpg
-Thanks
Update: I send Fractal Design a message. Thanks for the help :)
Update 2: I glued it back on and it works like a charm. Ill send it back if it falls off though.
https://linustechtips.com/topic/174494-define-r4-problems/
RMA or exchange it from the place of purchase.
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 6x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
https://linustechtips.com/topic/174494-define-r4-problems/#findComment-2317482
Contact fractal about it  I'm sure they'd be happy to send you a replacement in no time
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/174494-define-r4-problems/#findComment-2318862
