so with my build i dont know witch case to get and i want it to look goo with a side window. and a white black and little gold colour scheme.
my parts.
m/b: asus z97 pro
cpu: 4790k
ram: corsair dominator platnium 16gb (looks good imo)
psu: corsair rm 750
hdd: western digital red
ssd: intel 730 240gb
cpu cooler: corsair h100i
graphics card: asus gtx 780ti
case: ????? HELP PLEASE
sleeving: something havent decided yet but will be white
please help me find a good case, i like cases that dont have a lot of detail eg: raidmax agusta. i like something like corsair 750d, h440, define r4.
my budget is 200$ new zealand
https://linustechtips.com/topic/174174-need-help-deciding-on-case-help-please/
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146181&cm_re=nzxt_phantom-_-11-146-181-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119260
Beware, Plastic alert , Otherwise you should go for coolermaster but it only comes in black *dramatic music* B)
Details separate people.
I'd go for an H440 or a Phantom. White of course. :)
This is what I was thinking as well.
<p>CPU: AMD FX-8320 @ 4.0 GHz | GPU: Asus GTX 970 STRIX | RAM: 8GB (2x4GB) Corsair Vengeance LP 1600MHz | Motherboard: Gigabyte GA-970A-UD3P ATX | SSD: Samsung 840 EVO 500GB (Boot Drive) | HDD: 500GB | Case: Corsair SPEC-02 Red |PSU: Corsair 750W | OS: Windows 7 64-Bit | Mouse: Corsair M65 (Black) | Keyboard: Corsair K95 RGB (Black w/ Brown Switches)
since you are looking at the DCUII GPU, i'd opt for an open front air flow case to
provide plenty of air in. for that i'd suggest either the arc midi R2 or the enthoo pro.
the closed front cases are swell for low noise (if you think that), but air flow is a
necessity for open cooler GPU to vent the case quick.
I personally own a red/black H440 and plan to do a build in it this summer. It's an amazing case with an amazing look. Though I have never been comfortable with what I've seen of the Phantoms build quality it does get good reviews and does look amazing. Ya gotta love NZXT cases
