You can always get an M.2 adapter like this http://www.amazon.com/Intel-Network-7260-HMWG-Wireless-AC-Bluetooth/dp/B00DMCVKMU  you should get both antennas and install them later.
USB adapters with external antennas are pretty decent too http://www.newegg.com/Product/Product.aspx?Item=N82E16833166103
Any reason for crossfire 280s? Unless yo're upgrading and already have one 280, crossfire doesn't make a whole lot of sense versus just one hirer end card.
N64 HTPC: [Completed]
Main PC: i7 4770k @ 4.2 Ghz | Be Quiet! Dark Rock TF | Asus Z87 Maximus VI Formula | G Skill Ripjaws X 16GB | Zotac GTX 1070 | Samsung 850 EVO 500GB | Seagate 1TB Hybrid | Samsung 840 EVO 128GB | Corsair 1200i | Thermaltake Core P5
You could also get a usb one. Its not fast but it works, and you shouldn't be using wifi for gaming anyways.
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
You have little choice but USB but that's not a big deal because USB isn't exactly a bottleneck for wireless n speeds. These things aren't going to push speeds much above 80Mbps let alone 400Mbps or so and the added latency is trivial compared to the couple of ms that WiFi adds. Also if you're getting one I'd suggest an N600 class adapter, N300 is pretty anaemic. Also don't get a no-name brand. You want sub $30?
http://www.amazon.com/NETGEAR-RangeMax-Wireless-N-Adapter-WNDA3100/dp/B001498LIO/
...... there you go, sub $30, fits your requirements, good brand, better spec than both the ones you linked. Also I have that exact same adapter (it was free with my router in a promo Negear was doing) and it's pretty solid.
Fools think they know everything, experts know they know nothing
Never considered an M.2 one. Plus it has Bluetooth. Definite maybe.
I have one (in the mail) and don't want to eliminate the possibility of crossfire if i ever need. I probably never will but I'm always paranoid about upgradeability.
No other choice.
What case do u have? it should fit if u have the first card in the top slot and the second in the bottom.
Cooler Master N200
Another definite maybe.
No other choice.
Powerline.
Thats msata his board has m.2 he will have to get an adapter if they even make them.
Woops, I linked the wrong adapter!
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106229
This is pretty much the same intel adapter, but on m.2
lcater95
Btw, USB 3.0 adapters with external antennas are quite decent.
