Hi guys,
So this is my first post on here, I literally made the account minutes before this, but I've been watching Linus for a while now. Anyways as you may or may not be able to tell, I'm looking to buy some LED strips, not CCL, but LED.
I'm looking for some blue or UV blue ones. I want them to really be blue not purple or anything else. I would like a blue shine to go with my build. If it was something really easy for me to just strap down or tape and pull and play I would appreciate it, if it takes some wire working to make it work then I don't mind but if it is intensive I would prefer it not be suggested.
If anyone could point me in the right direction I would really appreciate it.
Also, if anyone could tell me how to setup the LED's that they suggest I would appreciate that too.
Thanks guys,
Cheese
I'm a student currently attending the University of Michigan-Ann Arbor, if you attend or around there please don't hesitate to contact me!
Mudkip: CPU: i5-4670k; Cooler: CM Hyper 212 Evo; Memory: 16GBs Corsair Vengeance DDR3 1600MHz; Motherboard: Gigabyte Z97X UD5H; GPU: ASUS DCUII 770 2GB @ 1254MHz; HDD: Seagate Barracude 1TB; PSU: CX750M; Case: ThermalTake A31 Chaser Thunder
https://linustechtips.com/topic/174108-led-accent-lights/
I've already looked into it. I just wanted to know if people had any ones that they liked a lot. For some reason I trust people on here then most places sooooooooooooo hahaha.
https://linustechtips.com/topic/174108-led-accent-lights/#findComment-2312505
Hi guys,
Thanks guys,
Cheese
The big two people usually I see go for are the NZXT Hue and bitfenix alchelmy strips, note the NZXT Hue needs a 5.25" drive bay.
For LED strips the most important thing for mounting is just letting the glow be seen and none of the actual LED's since the light from them is pretty harsh, you could also add a light diffuser strip or cover over the LED strip to prevent reflections in the case especially if you have a gloss white finish on the inside.
https://linustechtips.com/topic/174108-led-accent-lights/#findComment-2313683
