I want to find a good triple-moniter 1440p card or cards. I want to be able to play almost all of my games at 7680 x 1440 with all of the eye-candy turned up all the way.
you do know it will need at least 3 GPUs maybe even 4 GPUs to drive 3 1440P monitors?
you need to look at least 3 x R9 290/X in Crossfire config
Ultra settings you might only get 30-40fps maybe even lower
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/173632-i-need-help/#findComment-2306039
You'd be able to get like max 30 FPS with 2 R9 290Xs, maybe think about triple 1080p or a 4K curved display maybe.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/173632-i-need-help/#findComment-2306047
Cross fire Two 290Xs, or SLI Two 780Ti's, or go with a Dual GPU Card/s straight away Like 690/s or 7990/s, but i believe two 290s with that massive Interface Can Handle it, and so does the mighty 780Ti's
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/173632-i-need-help/#findComment-2306055
Multiple R9 290X, or R9 295X X2, or Titan blacks.
Still to max out this res you will need at least 2 gpus. The best for the money would be getting 3 R9 290Xs and slapping some pretty powerful fans near them (side panel for example), and being sure you have good airflow. Even still you won't be able to go Ultra with 60 fps+ on many games, you would have to drop some settings, or making sure you can cool those GPUs enough for a bigger OC
https://linustechtips.com/topic/173632-i-need-help/#findComment-2306059
I think Linus should do a exterme benchmark video with this setup.
newegg has a similar 4 GPU X-Fire setup with 3 1600P monitors and with dual 295x2
https://linustechtips.com/topic/173632-i-need-help/#findComment-2306185
But I Want Nvidia Benchmarks.
https://linustechtips.com/topic/173632-i-need-help/#findComment-2306245
Multi Moniter benchmarks
older using 4 x Titan original and three 1600P monitors
https://linustechtips.com/topic/173632-i-need-help/#findComment-2306334
