PCPartPicker part list: http://pcpartpicker.com/p/6t37pg
Price breakdown by merchant: http://pcpartpicker.com/p/6t37pg/by_merchant/
CPU: Intel Celeron G1820 2.7GHz Dual-Core Processor  ($44.99 @ Newegg)
Motherboard: MSI H81M-E33 Micro ATX LGA1150 Motherboard  ($44.99 @ Micro Center)
Memory: Kingston Fury Series 4GB (1 x 4GB) DDR3-1600 Memory  ($37.99 @ Amazon)
Storage: A-Data Premier Pro SP920 128GB 2.5" Solid State Drive  ($69.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.91 @ OutletPC)
Case: BitFenix Merc Alpha (Black) ATX Mid Tower Case  ($34.99 @ NCIX US)
Total: $285.86
There is no need to invest 600$ for a browsing machine. Also since Microcenter does price match there is nothing to worry about.
https://linustechtips.com/topic/173578-best-600-pc-build/#findComment-2305377
Total: $285.86
I really like this build, I'd change the processor to a Pentium G3220 personaly.
"If violence does not work, try more violence"
https://linustechtips.com/topic/173578-best-600-pc-build/#findComment-2305389
I would say go with 8 gb of ram but the rest of the parts listed above are good.
<p>CPU: AMD FX-8320 @ 4.0 GHz | GPU: Asus GTX 970 STRIX | RAM: 8GB (2x4GB) Corsair Vengeance LP 1600MHz | Motherboard: Gigabyte GA-970A-UD3P ATX | SSD: Samsung 840 EVO 500GB (Boot Drive) | HDD: 500GB | Case: Corsair SPEC-02 Red |PSU: Corsair 750W | OS: Windows 7 64-Bit | Mouse: Corsair M65 (Black) | Keyboard: Corsair K95 RGB (Black w/ Brown Switches)
https://linustechtips.com/topic/173578-best-600-pc-build/#findComment-2305398
guys????
I would go for a Haswell i3 and 8gb of ram, so the PC will last a long time before an upgrade. And if he wants to game later on, he can add a GPU and have a decent gaming system.
Total: $285.86
There you go :) 350 bucks
-edit-
didn't see the microcenter thing, try and see if they have these parts
https://linustechtips.com/topic/173578-best-600-pc-build/#findComment-2305638
guys????
For a more "future proof" build, with a lot more of horsepower, you can build this.
Top of the line CPU, quiet cooler, decent mobo that will support future processors, enough ram and an SSD, 1tb for mass storage, and a PSU that will handle a GPU in the future (or whatever you want to put on it). The case is a basic good looking case.
PCPartPicker part list: http://pcpartpicker.com/p/jyHCFT
Price breakdown by merchant: http://pcpartpicker.com/p/jyHCFT/by_merchant/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($199.98 @ SuperBiiz)
CPU Cooler: Cooler Master RR-H101-22FK-RI 30.0 CFM Sleeve Bearing CPU Cooler  ($18.98 @ SuperBiiz)
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard  ($79.99 @ Amazon)
Memory: Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600 Memory  ($72.99 @ Amazon)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($64.99 @ TigerDirect)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.92 @ Amazon)
Case: Rosewill Line-M MicroATX Mini Tower Case  ($37.25 @ Amazon)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Newegg)
Total: $582.09
https://linustechtips.com/topic/173578-best-600-pc-build/#findComment-2305764
Total: $582.09
hey sorry the build has gone up to $1000 in a nzxt h440 case
https://linustechtips.com/topic/173578-best-600-pc-build/#findComment-2305823
Truly depends on what you want to do with the PC. A $200 i5, will last a LONG time, running work applications and casual stuff. A GPU will serve you great to run games, and a more powerful processor, is going to be a great choice if you want to edit, transcode, and do many other intensive tasks.
If you want a premium feel on the PC and are willing to put more money into it, you can go for pleasing aesthetics, top tier SSDs, very quiet components (such as coolers fans and PSU), or really good peripherals.
Get a really good mouse, a mechanical keyboard, a good monitor with a nice res and outstanding colors, upgrade your sound, and many more other things, where you can spend your money to get that premium PC, instead of buying an i7 that will never have to go over 10% load to carry such tasks.
https://linustechtips.com/topic/173578-best-600-pc-build/#findComment-2305914
