not sure why my python 3 code isnt working
Solved by CornOnJacob,
i fixed that but the error is in the while loop
-snip-
The way you have it now, i.e.
while menu_input != "i" or menu_input != "I" or menu_input != "p" or menu_input != "P" or menu_input != "q" or menu_input != "Q":
at least one of those conditions will fail, because menu_input can't equal "i" and "p" at the same time. While menu_input does not equal "i" or it does not equal "p", it will display "invalid menu choice." You made a Catch-22 conditional.
