Stuck between the Beyerdynamic DT 990 Pro 250 Ohm and AKG K240 MKII
Solved by NannerBeans,
The DT 880 are a bit above my budget though...
Oh are they priced higher? Well go for the DT990 then.
Featured Topics
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
2
7
1
Shane Martin ·
Posted in Displays2 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2 -
PatRed ·
Posted in New Builds and Planning8
