buy one dvi to vga adapters and use VGA. use hdmi with the other.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/171521-help-with-dual-monitors/#findComment-2278959
you dont need one. you can get a wire for £2 that had hdmi on one end and dvi on the other :)
well it's still technically an adapter, just cable included =P Never seen those either though.
When I buy my monitors I make sure they have DVI ports on them so I dont have this problem.
https://linustechtips.com/topic/171521-help-with-dual-monitors/#findComment-2279693
