I have 3 of these bastards and not all them go to max res
one of them uses a display port adapter, I tried hdmi to monitor and hdmi-dvi to monitor and same thing
can those not handle a higher res? the other 2 are hdmi and dvi to hdmi?
I switched gpus to try each one same result I decided to just order a display port cord but just to make sure.
adding a 2560x1080 doesn't work for me manually, it doesn't let me use it in surround so that is not an option
been messing around for hours cannot do anything.
http://i.imgur.com/wqkxdDn.jpg
CPU: i9 19300k////GPU: RTX 4090////RAM: 64gb DDR5 5600mhz ////MOBO: Aorus z790 Elite////MONITORS: 3 LG 38" 3840x1600 WIDESCREEN MONITORS
https://linustechtips.com/topic/171270-lg-25um64-res-problems/
