So I accidentally while I was in my Nexus 5's boot loader went to wipe all the cache and partition and I quickly rebooted my device. Now I can't do anything and the google play store does not work all my gallery pics are gone and the Google Play services error keeps popping. So I decided to go to my bootloader and go to recovery mode and now nothing in recovery mode will work it will only show the dead android
$$金Trill金$$
https://linustechtips.com/topic/171069-help-men-phone-problem/
heres your problem:  went to wipe all the cache and partition... why would you even need to do this?
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/171069-help-men-phone-problem/#findComment-2273292
try and resurrect it through this:http://www.wugfresh.com/nrt/
https://linustechtips.com/topic/171069-help-men-phone-problem/#findComment-2273403
the link is not working for me
The website must be down, its called nexus root toolkit search it later once their website is back up.
https://linustechtips.com/topic/171069-help-men-phone-problem/#findComment-2286076
