Soooo, my sister is kind of dumb, and has asked me to find her headphones with very odd perimeters.  Here we go.
I need the best headphones that are:
A.  White...  Also that don't look awful
B. are under $30
C. I know for $30 nothing is going to sound good, but something that isn't abysmal.
Thanks!
https://linustechtips.com/topic/169975-need-a-dumb-product/
https://linustechtips.com/topic/169975-need-a-dumb-product/#findComment-2259462
Haha you guys are spot on! She actually bought those but they were too uncomfortable!
https://linustechtips.com/topic/169975-need-a-dumb-product/#findComment-2259467
buy her theese
http://www.amazon.com/Incipio-NX-101-Hi-Fi-Stereo-Headphones/dp/B005Q311OK/ref=sr_1_4?s=electronics&ie=UTF8&qid=1403425476&sr=1-4&keywords=f38
no under 30$ but sound is superior to anything out there for same dosh
yea they look kinda silly, but your sis is too :D not every headphone can produce good sound
https://linustechtips.com/topic/169975-need-a-dumb-product/#findComment-2259469
AHAHAHHAHAHAHAHhahahahaha.
Sexist pig....
Superlux has white headphones for $40 and those are freaking amazing for the price so that's prolly the route I would go. Idk at $30 though.
The hd661 evo?
https://linustechtips.com/topic/169975-need-a-dumb-product/#findComment-2259473
Sexist pig....
well there is turquoise color too for same price...
and im not sexist, are you feminist? :P you probably wear pink clothes...
i was not joking. theese headphones have great sound quality and clarity. look it up.
The hd661 evo?
681 EVO yes, perfect how could we forget :D
oh the price went up, better buy black color
https://linustechtips.com/topic/169975-need-a-dumb-product/#findComment-2259489
$40 should be fine!
https://linustechtips.com/topic/169975-need-a-dumb-product/#findComment-2259509
not a feminist, I do not wear pink, I simply am pointing out cultural travesties... And fair enough I assumed they were craptastic.
there are 2 colors @ 37$ so i picked pink based on cultural travesties :D
those are awesum headphones, but evos are better, less clear but semi open, comfy, good looking, bass and some sub
https://linustechtips.com/topic/169975-need-a-dumb-product/#findComment-2259525
I like how they look like beats.
They should put up a tag line, 'beats, as how they should be priced...' :P
https://linustechtips.com/topic/169975-need-a-dumb-product/#findComment-2259707
