Pc turns on, then turns off and than turns on again without displaying something
Solved by jackninja1,
So yeah I unplugged and plugged my cables like ten times, took my whole rig apart. And in the end a ragefist to da table made it work. Seriously I hit the table and the pc booted and it is working now.
It was probibly a bad cableconnection or a cable that is broken. If you have the same problems as I did try to check the connections of your pc, like your powercable.
Thanks for everyone that helped me you guys are great!
